Command | Description |
show | Displays settings for the specified system component |
adoption | Displays adoption related information |
bluetooth | Displays Bluetooth radio statistics for RF Domain member access points |
boot | Displays a device's boot configuration |
bonjour | Displays the configured Bonjour services available on local and remote sites |
captive-portal | Displays WLAN hotspot functions |
captive-portal-page-upload (show commands) | Displays captive portal Web pages upload related information |
cdp | Displays a CDP (Cisco Discovery Protocol) neighbor table |
classify-url | Queries a specified global data center or a pre-configured classification server for the category of a specified URL. |
clock | Displays the system clock |
cluster | Displays device-cluster related statistics |
cmp-factory-certs | Displays factory installed CMP certificates |
commands | Displays command list |
context | Displays information about the current context |
critical-resources | Displays critical resources deployed within the managed network and associated statistics |
crypto | Displays encryption mode information |
database | Displays database-related statistics and status |
device-upgrade | Displays device firmware upgradation information for devices adopted by a wireless controller or access point |
dot1x | Displays dot1x information on interfaces |
dpi | Displays statistics for all configured and canned applications |
environmental-sensor | Displays environmental sensor‘s historical data (applicable only to AP 8132) |
event-history | Displays event history |
event-system-policy | Displays event system policy configuration information |
ex3500 | Displays EX3500-related statistical data |
extdev | Displays external device (T5 or EX3500) configuration error history |
fabric-attach | Displays the current status of VLAN to I-SID assignments for all ports |
file | Displays file system information |
file-sync | Displays file synchronization settings and status on a controller. The file-sync command syncs trustpoint/wireless-bridge certificate between the staging-controller and its adopted access points |
firewall | Displays wireless firewall information |
global | Displays global information for network devices based on the parameters passed |
gps (show command) | Displays the geographical coordinates (latitude and longitude) of the device for which the GPS coordinates search process has been triggered |
gre | Displays GRE tunnel related information |
guest-registration | Displays guest registration statistics based on the option and time entered |
interface | Displays interface status |
iot-device-type-imagotag | Displays the configuration of ESL communicator on a specified AP or on all APs within an RF Domain. |
ip | DisplaysIP related information |
ip-access-list-stats | Displays IP access list statistics |
ipv6 | Displays IPv6 related information |
ipv6-access-list | Displays IPv6 access list statistics |
l2tpv3 | Displays L2TPv3 (Layer 2 Tunnel Protocol Version 3) information |
lacp | Displays LACP (Link Aggregation Control Protocol) related information |
ldap-agent | Displays an LDAP agent‘s join status (join status to a LDAP server domain) |
licenses | Displays installed licenses and usage information |
lldp | Displays LLDP (Link Layer Discovery Protocol) information |
logging | Displays logging information |
mac-access-list-stats | Displays MAC access list statistics |
mac-address-table | Displays MAC address table entries |
macauth | Displays details of wired ports that have MAC address-based authentication enabled |
mac-auth-clients | Displays MAC-authenticated clients based on the parameters passed |
mint | Displays MiNT protocol configuration commands |
ntp | Displays NTP server related information |
password-encryption | Displays password encryption status |
pppoe-client | Displays PPPoE (Point to Point Protocol over Ethernet) client information |
privilege | Displays current privilege level information |
radius | Displays the amount of access time consumed and the access time remaining for all guest users configured on a RADIUS server |
reload | Displays scheduled reload information |
rf-domain-manager | Displays RF Domain manager selection details |
role | Displays role-based firewall information |
route-maps | Display route map statistics |
rtls | Displays RTLS (Real Time Location Service) statistics of access points |
running-config | Displays configuration file contents |
session-changes | Displays configuration changes made in the current session |
session-config | Displays configurations made in the current session |
sessions | Displays a list of currently active open sessions on the device |
site-config-diff | Displays the difference between site configuration available on NOC and the actual site configuration |
smart-rf | Displays Smart RF management statistics |
Displays the SNMPv3 Engine ID |
spanning-tree | Displays spanning tree information |
startup-config | Displays complete startup configuration script on the console |
t5 | Displays adopted T5 controller details. This command is applicable only on the RFS 4000, NX 95XX, NX 96XX, and VX 9000. |
terminal | Displays terminal configuration parameters |
timezone | Displays timezone information for the system and managed devices |
traffic-shape | Displays traffic-shaping related configuration details and statistics |
upgrade-status | Displays image upgrade status |
version | Displays a device's software and hardware version |
vrrp | Displays VRRP details |
virtual-machine | Displays the VM (virtual-machine) configuration, logs, and statistics |
web-filter | Displays pre-configured, in-built Web filter options available. These options are: category (URL category), category-types, filter-level, etc. This command also displays Web filter statistics and status. |
what | Displays details of a specified search phrase |
wireless | Displays wireless configuration parameters |
wwan | Displays the wireless WAN status |
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.
